Use standard trim, airbag and buttons on a M steering wheel?
Diskutiere Use standard trim, airbag and buttons on a M steering wheel? im Allgemeines zum BMW 1er F2x Forum im Bereich Informationen zum 1er und 2er F-Modell ab 2011; I hope you will forgive me for writting in English. It is not perfect, but much better than my German. You can reply in German if you like....
  1. #1 Carsten BMW 114D, 05.08.2013
    Carsten BMW 114D
    Carsten BMW 114D 1er-Interessent(in)
    22.07.2013
    I have purchased a nice M steering wheel as a replacement for my standard leader steering wheel. BUT I am missing the airbag and the buttons for this.
    I wonder if there is a cheap solution. The "sports" airbag always go with the "sports" trim and "sports" buttons.
    I think the steering wheel could be similar, but the loose parts is different. The trim from the sport and M sport is in aluminium and goes up on the sides of the airbag. So the "sport" airbag is a little smaller to give room for this. And the button section is different as there is a hole to mount / click on the trim.
    So instead of changing the buttons and the airbag on this lovely M steering wheel, then I wonder if I could just change the trim. It will of course not look as good as with the aluminium look. But it will be cheap as I have all parts.
    And the feel will be the same. And I wonder if it is worth 500 euro to have the Alu trim.
    Do anyone know if this solution could work?
    And do you know how to remove the trim? Is there any screws?
  2. Flob
    Flob 1er-Guru
    06.07.2007
    7.038
    83
    Do you really mean the new F20-BMW? Not E8X?
  3. #3 Carsten BMW 114D, 05.08.2013
    Carsten BMW 114D
    22.07.2013
    Yes I do.
    It is a 5 door 114D from May 2013
  4. hossi
    hossi 1er-Profi
    25.11.2007
    2.761
    108
    78532 Tuttlingen
    Falk
    Could you take some pictures for a better understanding. :wink:
  5. #5 Carsten BMW 114D, 06.08.2013
    Carsten BMW 114D
    22.07.2013
    I don´t have any good pictures, but leebmann has some good pictures.
    For the sport version:
    BMW Ersatzteile Teilekatalog - leebmann24.de
    Here part 3 have some mounting holes for the trim or abdekung part 6. Part 6 the trim is having the lower black part and also the aluminum part which is on both sides of the airbag. The airbag part 9 is having a little different shape than the standard airbag.
    For the standard version:
    Here part 3 doesn´t have the mounting holes on the side facing against the airbag. It is more smoot.
    The trim part 6 is smaller. Here it is only the bootom half of what is one the sport version.
    Part 9 the airbag has a different shape. It looks like it is different to match the shape of the trim.
    Is it more clear now, or is actual pictures needed??
Use standard trim, airbag and buttons on a M steering wheel? - Ähnliche Themen
  1. BMW M Performance Parts im Leasing
  2. BMW M Performance Parts im Leasing
  5. BMW M Performance Mittelkonsolenblende Gangwahlschalter
    BMW M Performance Mittelkonsolenblende Gangwahlschalter: Hallo, suche originale BMW M-Performance Blende für den Gangwahlschalter Automatik. Teile-Nr. 51162343739
