Problem with aftermarket radio
Diskutiere Problem with aftermarket radio im HiFi, Navi & Kommunikation Forum im Bereich Allgemeines zu den 1er BMW Modellen; First - sorry for posting in english, but my written german would be impossible for you to understand I think... I can however read replies in...
  1. oreo
    oreo 1er-Interessent(in)
    05.08.2006
    First - sorry for posting in english, but my written german would be impossible for you to understand I think... I can however read replies in German if you prefer.
    This morning my car had a (presumably) faulty indication of worn breakpads, so I took it by the BMW garage to have it checked. They did, however, claim that they could not get in contact with their sensors as I had replaced the original Business radio with an aftermarket unit. I have installed a 2nd Generation Dietz CANBUS adapter, which I thought would emulate the radio and not cause these problems. Have anyone else with aftermarker radios had problems during services or checks at BMW, or am I the only one with this problem??
    Thankful for all help on this!
  2. slazer
    slazer 1er-Fahrer(in)
    14.01.2007
    417
    123d Coupé
    Jens
    Hmm you should speak to an other BMW Dealer, you are defently allowed to change youre Radio even to the Car Warranty this has no effect, so if you dont have damaged anything with this its not youre Problem that the BMW Garage wasnt able to check. I think the only havent the right Tools like Diagnostics Computers etc. Cause 3 of my friends one with an 118i and the 2 others with 328i and 318d have replaced their Radios with aftermarket ones an the have no trouble with BMW service or anything else one of them had a failure in his Board Computer but no problem the Dealer replaced it an no more trouble .... with out saying anything to the aftermarket Radio.
    Best regards Jens
    by the way i think most of the Users of this forum were able to read and write the english language even when some of them including me make some mistakes by writing in english :oops:
  3. oreo
    05.08.2006
    Thank you very much for your input! Do you know if your friends used CANBUS adapters when they changed the radios or maybe there was no original radio in the 118i to start with? Right now I think that I should have got my car without the original radio and made a clean install myself...
  4. slazer
    14.01.2007
    417
    123d Coupé
    Jens
Problem with aftermarket radio - Ähnliche Themen
  1. Problem mit dem Komfortschließen
    Problem mit dem Komfortschließen: Hallo! Mein E88 hat das Komfort Paket zum Öffnen und Schließen der Fahrertür ohne Schlüssel. Ich muss also nur die Hand in die Griffmulde schieben...
  2. Fragen zum Wechsel der Antriebswellen (DSC-Problem)
    Fragen zum Wechsel der Antriebswellen (DSC-Problem): Hallo! Ich möchte die Antriebswellen (li+re) selber tauschen da der ABS-Sensorring unterrostet ist. Ich habe aber noch ein paar Fragen: Es geht...
  3. Vorstellen und Problem
    Vorstellen und Problem: Hallo zusammen Mein Name ist Elmar, ich komme aus Österreich und fahre einen 135i E82 mit N55 Motor. Leider bräuchte ich schon eure Hilfe. ich...
  4. Elektronik problem
    Elektronik problem: Hallo Leute, ich habe ein problem mit meinem E87 BJ 2010 Es sind vershiedene Kontrolleuchte an (ABS, Airbag, Lenkung, Rote Hebebühne). Und einige...
  5. Problem mit Revolutionen
    Problem mit Revolutionen: Hallo, ich habe ein Problem, das "zufällig" auftritt, manchmal passiert es, manchmal nicht, die Umdrehungen bleiben "schwebend in...
