Need more power!
Diskutiere Need more power! im BMW 130i Forum im Bereich Informationen zum 1er E-Modell 2004-2013; I have a 4/2006 130i E87. What is that can be done to the engine (valvetronic) in order to gain some power? Right now i have only K&N filter...
  1. #1 karlenstein, 30.06.2009
    karlenstein
    karlenstein 1er-Interessent(in)
    30.08.2008
    30
    Right now i have only K&N filter + remap. Exhaust is 100% standard.
    What would you reccomend to make the car (a lot) faster? :roll:
    Any camshafts available for valvetronic engine? Or... ??
    Let me know your ideas.
    Karl (Rome, Italy)
  2. #2 lalamite, 30.06.2009
    lalamite
    lalamite 1er-Fahrer(in)
    28.05.2008
    326
    a lot faster???
    I think the best tip would be buying a new car :P
  3. #3 Catahecassa, 30.06.2009
    Catahecassa
    Catahecassa 1er-Guru
    20.03.2008
    9.917
    Ciao Karl, do you have a manual shifter?
    Then you can use a shorter final drive, which makes you can much quicker in all gears. But the top speed will be degraded. Engine can not be upgraded seriously ... just a few HP or NM with Chiptuning ... no price relation though :wink:
  4. #4 der_haNnes, 30.06.2009
    der_haNnes
    der_haNnes 1er-Guru
    27.10.2007
    8.715
    no, he cant. the shorter final drive is only available for the LCI 130i.
    seriously, there is no cheap way to improve the performance of the engine. with both the BMW Performance intake and exhaust system i gained ~ 10 HP, and strangely it appears that the quaife limited slip differential has less loss in the powertrain then the original BMW part (is that even possible?). i guess a serious ECU remap can add another 10-15 HP but thats it. all other modifications are way too expensive.
  5. Nemi
    Nemi 1er-Fahrer(in)
    19.03.2009
    182
    Dormagen
    I agree with the others. You could go to Noelle and get yourself an upgrade to 306 HP which is done by massive mechanical changes within the engine itself.
    But this costs more than 10k (in €). You could also install a high performance header from supersprint (also quite expensive 1.3k) and high performance exhaust system with metall cats.
    As a result you are better of buying a 135i instead of spending loads of money into the tuning. Furthermore, the 135i has much more tuning potential in terms of engine performance than the already pretty much maxed out 130i engine. Turbo engines are a lot easier and cheaper to tune than non-turbos.
    Think about it 8)
  6. #6 bmdoubleyou, 30.06.2009
    bmdoubleyou
    bmdoubleyou 1er-Liebhaber(in)
    03.03.2008
    1.852
    Hello,
    there are a few Tuner, who bring this engine to roundabout 290ps, but in a very expensive way. If I´m right, then they put a new cylinder insert into the (engine)motorblock with 6 new pistons and a new crank to increase the range of the pistons, so they can reach 3200ccm. Additionally they adapt the software und some more little things. If you ´re thinking of installing a compressor, my opinion is to say: You shouldn´t do that, because of the high pressure in the Engine. Maybe there are some Specialists, who knows exactly what they are doing with a compressor engine (for example, to lower the Compression). For me, it is much too dangerous.
  7. Nemi
    Nemi 1er-Fahrer(in)
    19.03.2009
    182
    Dormagen
    Yupp, it is Noelle who does this 3,2 Liter upgrade which I have refered to as well :D
  8. #8 bmdoubleyou, 30.06.2009
    bmdoubleyou
    03.03.2008
    1.852
    Ah ok. thank you - YOUR`E WELCOME :thumbsup: and also RACING DYNAMICS , I think.....
  9. #9 Forums Plugin, 30.06.2009
    Forums Plugin
    14.10.2008
    4.372
    Frankfurt am Main
    Buona sera, Karl,
    there are several ways to make a(ny) car faster - are you just looking for a better acceleration or an increased top speed or is it track time you are after?
    If it's about going faster around a track, I would recommend to change several things first before touching the engine... for acceleration from low speeds there are also some changes possible besides power upgrades (tires, gearbox, limited slip differential)
  10. #10 nightperson, 01.07.2009
    nightperson
    nightperson 1er-Guru
    07.11.2005
    6.927
    Kaarst
    Hi Karl, you can gain around 20 HP and app. additional 15 kms of top speed by just chip tuning the car, mainly because of the 250 kmph limiter will be removed. Anything which goes beyond that would become quite costly (mechanical changes, cams, exhaust systems etc.).
    Cheers,
  11. #11 Sternspeiche, 01.07.2009
    Sternspeiche
    Sternspeiche 1er-Liebhaber(in)
    19.05.2009
    1.170
    Turn off your DSC completely and you'll see that it's already too powerful for daily use :mrgreen:
  12. #12 AnooooOH, 03.07.2009
    AnooooOH
    AnooooOH 1er-Süchtling
    06.05.2009
    10.979
    58
    Goslar/NDS
    04/2014
    Phil
    cams...the next step would be forced induction.
  13. #13 der_haNnes, 03.07.2009
    der_haNnes
    der_haNnes 1er-Guru
    27.10.2007
    8.715
    guess not.
  14. #14 karlenstein, 05.07.2009
    karlenstein
    30.08.2008
    30
    Dear All, thanks for you replies.
    I am a trackday addict so i already made these mods:
    - quaife atb diff
    - bilstein b16 pss9 suspensions
    - K-mac front adjustable camber plates
    - H&R uprated swaybar kit
    - BMW Performance Big Brake Kit + ProjectMu HC+ pads
    - Toyo R888s on OZ Ultraleggera wheels
    - K&N airfilter
    - ECU remap
    Previously i had the Gruppe-M airbox and the BMW Performance exhaust but i sold them due to the fact that they were giving almost none "noticeable" power but only a great sound (like an M3) and i needed bigger brakes (they are grrrrreat!).
    So the car handles great at track but it lacks some "extra kick".
    You can see some videos here:
    http://www.youtube.com/carlettosan
    I agree with some of you who say that in the end it's cheaper/easier to buy another car (this is what i already thought) but needed an extra confirmation that there are no other option than doing some 10K eur mods to achieve the 306ps (which i am not willing to spend).
    Maybe a 135i M would be best or a Z4 M Coupe' (which i love very much).
    Too bad cause i like my 130i very much!
    Greetings!
    Carlo
    PS - DSC and all the other elctronic stuff are always 100% off!
  15. #15 Catahecassa, 06.07.2009
    Catahecassa
    20.03.2008
    9.917
    Ciao Carlo,
    as I see in your mod list, you are close to the maximum. Ob the exhaust system some HP are available, still :nod:
  16. #16 karlenstein, 06.07.2009
    karlenstein
    30.08.2008
    30
    I still cannot believe that in Germany no tuner has made a specific commercially available exhaust manifold for the 130i....
    Supersprint in Italy has an overall "good" reputation but i would never put their products on a German car (especially mine).
    I expect the expertise is more on the German land rather than Italy on a BMW.
    Ciao, Carlo
    PS - Check this out: http://www.youtube.com/watch?v=n9QWO6ZykrE
    This is from latest trackday at Vallelunga Track near Rome! :wink:
  17. Nemi
    Nemi 1er-Fahrer(in)
    19.03.2009
    182
    Dormagen
    Impressive mod list.
    You surely are an trackday addict :D
    Are you satisfied with your quaife LSD ? Does it change the drive experience a lot? Is it responsive enough for track purposes?
    I would realy appriciate it if you could give me some answers on the LSD topic.
    Martin
  18. #18 karlenstein, 06.07.2009
    karlenstein
    30.08.2008
    30
    I love it!
    Plus it's the the only LSD i know that does not need any mainteinance / overhaul so for "normal" trackday use and daily driving is perfect (not for races like the VLN i guess).
    :wink:
  19. #19 der_haNnes, 06.07.2009
    der_haNnes
    der_haNnes 1er-Guru
    27.10.2007
    8.715
    Nemi da gibts schon einige threads zu ... und falls du interesse an einem hast, schau ma in meine signatur :p
  20. Nemi
    Nemi 1er-Fahrer(in)
    19.03.2009
    182
    Dormagen
    Das weiss ich doch alles schon. Wollte mir einfach nur mal ne italienische Meinung einholen :wink:
    Hab den Typen bei dem du deinen Umbau gemacht hast angerufen. Er wollte mich 2 Tage später zurückrufen um mir ein Komplettangebot zu machen.
    Tja, hat bis heute nicht zurückgerufen. Werd bei Gelegenheit nochmal nachfragen... Muss schauen ob sich das Lohnt, meine Anfahrt ist nicht gerade die kürzeste....
Need more power!
Need more power! - Ähnliche Themen
  1. M Performance Power Kit 20d B47
    M Performance Power Kit 20d B47: Guten Morgen zusammen, ab heute sind die langersehnten BMW M Performance Parts Power Kits für den B47 20d bestellbar. Bestellbar für die...
  2. BMW M Performance Parts 20d B47 Power Kit
    BMW M Performance Parts 20d B47 Power Kit: nabend zusammen, ab morgen sind die langersehnten BMW M Performance Parts Power Kits für den B47 20d bestellbar. Bestellbar für die komplette...
  3. [E8x] Performance Flaps - schwarz lackiert - Mor Vision
    Performance Flaps - schwarz lackiert - Mor Vision: Hallo, ich räume meinen Keller auf und habe diese Flaps von Mor Vision noch über, die ich nur kurze Zeit an meinem alten Wagen verbaut hatte. Die...
  4. 120D Performance Power Kit -wo günstig einbauen lassen?
    120D Performance Power Kit -wo günstig einbauen lassen?: Hallo zusammen! ich würde mir gerne das Perf. Powerkit für meinen F20 holen. Der BMW-Händler in meiner Umgebung verlangt für den Einbau 1.300,-€...
  5. Performance Power Kit
    Performance Power Kit: Hallo Zusammen .. Ich habe kurz eine Frage und zwar habe ich mir heute denn Performance Power kit bei Bmw einbauen lassen.. Ich habe das Auto am...
