[E8x] Metallic rattle in front, when driving over small holes, macht mir verrückt! :(
Diskutiere Metallic rattle in front, when driving over small holes, macht mir verrückt! :( im Mängel an der Karosserie Forum im Bereich Mängel am 1er BMW; Hello all, my name is Igor, from Slovenia, I am writing you here about a problem that's been eating my nerves... I have the 2008 120d e87, its a...
  1. #1 beckerplast, 18.04.2015
    beckerplast
    beckerplast 1er-Fahrer(in)
    12.09.2012
    79
    Hello all, my name is Igor, from Slovenia, I am writing you here about a problem that's been eating my nerves... I have the 2008 120d e87, its a great car, with B12 Bilsteins, Eibach Prokit springs and HR sways front an rear.
    The sound:
    Lately i experience the never-ending metallic clunking when going over small bumps or cobblestone road... it can be felt in front left side (around the strut) and can be felt throught the steering column and steering wheel.
    not a clicking sound when I would turn the steering wheel, but a rattle up front, and sometimes in the rear back...while driving.
    but it gets better in wet weather, in rain... I have 2 theories I suspect - whether the rubber somewhere hardens when its rainy outside, or - the water "lubricates" something, and the sound /feel is not so "rattly" anymore...
    The feel:
    The other thing I noticed is when driving in a corner fast on a bad road. The front and also the rear feels really wobbly and maybe jerks (not slides) in direction of centrfugal force- outside of the curve.
    When I drive straight and I hit a larger hole with my left tyres, the car jerks to the left, feeling unstable. When driving straight!
    Does this fact directs you in any way towards some other cause for the rattle rather than upper strut mount?
    It has never been in an accident, and the wheel alignment is dead on. Camber in the rear and front is a bit larger (handling oriented). Tyres are new and centered.
    The rattle has been worse with putting summer 18" back on.
    I've read all possible forums and some suggest swaylinks (which are fine), other to change the whole suspension(checked 3 times by 3 different specialists, everythin tight), the to check the upper strut mounts (which optically are okay), I havent tested them for play yet. Then again some suggest the washers and the central nut in the upper strut may be causing the rattle.... i dont know any more...
    thanks... sooo desperate... ( it used to be a really tight car, and now this....)
  2. #2 Flo95, 19.04.2015
    Flo95
    Flo95 1er-Süchtling
    13.05.2013
    11.197
    2.496
    Stuttgart / Saarbrücken
    03/2011
    Florian
  3. #3 beckerplast, 19.04.2015
    beckerplast
    12.09.2012
    79
    Hm, bist du sicher? Habe den Schocks im ADAC Werkstatt getestet und geprüft, alle 4 sind perfekt im alle Moden : Rebound, fast bounce, slow bounce, alles!
  4. #4 beckerplast, 19.04.2015
    beckerplast
    12.09.2012
    79
    any other ideas maybe?
Metallic rattle in front, when driving over small holes, macht mir verrückt! :( - Ähnliche Themen
  2. Performance Front und Heck (auch M-Heck) f. E88/82
  3. [Verkauft] SK Challenge Carbon FrontFlaps M-Front E81/87
    SK Challenge Carbon FrontFlaps M-Front E81/87: Moin, aufgrund eines Fahrzeugwechsels biete ich einige Anbauteile zum Kauf an. Hier biete ich euch die SK Challenge Carbon Front Flaps für die...
  4. Tacho bzw Kombiinstoment spielt verrückt
    Tacho bzw Kombiinstoment spielt verrückt: Hallo, Bei den e87 118ia ist mir gestern Abend aufgefallen als ich ihn starten wollte das Zuerst im Display eine Rotehebebühne zu sehen war kurz...
  5. Suche E82 M Paket Front
    Suche E82 M Paket Front: Hi, alle Halter sollten natürlich in Ordnung sein. Am besten alpin weiß lackiert. Farbe spielt jedoch keine große Rolle. Gruss Max
