[E82] Intake for 125i INJEN
Diskutiere Intake for 125i INJEN im BMW 125i Forum im Bereich Informationen zum 1er E-Modell 2004-2013; Good afternoon, friends I want to know who installed it myself this Intake? Whether it is worth the money? What are the positive and negative...
  1. #1 Lunohod (RUS), 19.03.2013
    Lunohod (RUS)
    Lunohod (RUS) 1er-Fahrer(in)
    30.07.2011
    124
    Russia ( Moscow)
    03/2011
    Evgeniy
    What are the positive and negative factors you received during use?
    it is believed that the filter passes a lot of dirt in the motor!
    the specific interests: SP SERIES INJEN SHORT RAM AIR INTAKE FILTER SYSTEM BMW 328i 128i BLACK PIPING
    many thanks:aufgeregt:
  2. Patz
    Patz 1er-Fahrer(in)
    12.01.2013
    149
    I would not use it!
    The problem in Germany is that every part needs an official permission.
    I don't know if this thing has one. So maybe nobody here has installed this.
    The kit you have postet, contains some parts that (maybe) worsen the performance of the Air intake!
    The "BMW Performance air intake" could probably serve your needs!
  3. #3 Lunohod (RUS), 20.03.2013
    Lunohod (RUS)
    30.07.2011
    124
    Russia ( Moscow)
    03/2011
    Evgeniy
    I certainly know of the existence of a set of official BMW Performance Intake, but the point of this device in a more beautiful image of the engine compartment, as this device is a standard K & N filter and a carbon fiber body, the test does not work.
  4. #4 Lunohod (RUS), 26.03.2013
    Lunohod (RUS)
    30.07.2011
    124
    Russia ( Moscow)
    03/2011
    Evgeniy
    Friends, that no one is doing anything?
  5. Gunnar
    Gunnar 1er-Liebhaber(in)
    27.10.2009
    1.268
    17
    WN
    11/2013
    I also won't use it due to it's design with the ellbow and the small filter. From the pictures you postet it is not directly visible how it is installed in the compartment and if it really will help getting colder air to the engine like the serial installed air intake.
    Such systems like the one you posted are in my opinion not half worth of it's price. The ellbow normally is in direction to the ground where you suck dust and all the scrap on the street. The small filter has only a few percent of dust retention and performance like the OEM system which will result in getting less durability of the motor! And it is not guaranteed that you get more power due to this system on the other side...
  6. #6 Lunohod (RUS), 28.03.2013
    Lunohod (RUS)
    30.07.2011
    124
    Russia ( Moscow)
    03/2011
    Evgeniy
    HI,
    Here is a picture of how the filter is located under the hood
    There's also a video, it sounds like the filter in combination with the BMW exhaust performantse.
    I realized what filter you have in mind, saying that it goes from the bottom machine, this filter is set in place of regular boxes, and has no access from the bottom car, it's not cold cooling filter is the filter of zero resistance.
  7. #7 Lunohod (RUS), 03.06.2013
    Lunohod (RUS)
    30.07.2011
    124
    Russia ( Moscow)
    03/2011
    Evgeniy
    Hi all
    Finally I got my order from the U.S.
    Installation on a machine took a half hour to do everything myself slowly.
    At the moment the machine has great sound acceleration and quick response to the accelerator pedal.
  8. #8 griffin92, 03.06.2013
    griffin92
    griffin92 1er-Fahrer(in)
    03.04.2013
    86
    Miehlen (zw. Koblenz u. Wiesbaden)
    04/2012
    Jens
    More power? When sucking the air directly beside the hot engine? Hot air is reducing the power!
  9. Flo95
    Flo95 Moderator
    13.05.2013
    13.308
    4.395
    Ludwigshafen
    03/2011
    Florian
    From what I can see on the picture there's a head shield installed between the engine and the filter, so hot air should be blocked.
  10. #10 Lunohod (RUS), 03.06.2013
    Lunohod (RUS)
    30.07.2011
    124
    Russia ( Moscow)
    03/2011
    Evgeniy
    You are absolutely right :eusa_clap:
  11. #11 Lunohod (RUS), 03.06.2013
    Lunohod (RUS)
    30.07.2011
    124
    Russia ( Moscow)
    03/2011
    Evgeniy
    Yes capacity has increased, there are measurements that had American colleagues on the bench. There is a protective shield between the engine and the filter that does not suck hot air, just in front grilles are my guides that at the speed of direct more air to the filter.
  12. #12 E1ns5und20zigI, 05.06.2013
    E1ns5und20zigI
    E1ns5und20zigI 1er-Fahrer(in)
    29.05.2013
    110
    Landkreis Rosenheim
    06/2012
    Samuel
    So do you think all the hot air from the engine is blocked by a little piece of metal? I do not ... it will hoover too much hot air, maybe it won't if you open the engine cowling while driving...
  13. #13 Lunohod (RUS), 05.06.2013
    Lunohod (RUS)
    30.07.2011
    124
    Russia ( Moscow)
    03/2011
    Evgeniy
    When I'm on speed I have are special guides to take more air from the street, so the speed of my motor gets more air. When I'm on the up with some hot air motor takes, but it's better than not will receive nothing, because in the drain worth plastic box, in which at the Parking lot is not supplied at all no air hot not cold.
  14. #14 Lunohod (RUS), 05.06.2013
    Lunohod (RUS)
    30.07.2011
    124
    Russia ( Moscow)
    03/2011
    Evgeniy
    In Kürze werde ich tun, chip, der sehr interessant, die Ergebnisse, so wie ich in der Maschine installiert exhaust Performance und Aufnahme Injen, ohne nachrüsten Maschine auf chip gab 263 hp, ist es interessant zu erfahren ob die wird mit diesen upgrade.
  15. #15 pousa13, 05.06.2013
    pousa13
    pousa13 1er-Fanatiker(in)
    03.03.2009
    5.339
    713
    Erding
    Flo
    you mean only with the intake and the performance exhaust you received 263HP on the dyno? or did you mean with ecu tuning?
  16. #16 Lunohod (RUS), 05.06.2013
    Lunohod (RUS)
    30.07.2011
    124
    Russia ( Moscow)
    03/2011
    Evgeniy
    This is only Ecu tuning.
Intake for 125i INJEN - Ähnliche Themen
  1. Suche Bms intake
    Suche Bms intake: Neu oder gebraucht
  2. [Verkauft] MST Performance Air Intake Ansaugung BMW F20 F21 F22 F30 F32 F87
    MST Performance Air Intake Ansaugung BMW F20 F21 F22 F30 F32 F87: Biete hier mein neuwertiges MST Performance Air Intake an. Passt auf alle Baureihen mit dem N55 Motor. Kit ist unbeschädigt und voll...
  3. [Verkauft] BMS Intake Ansaugung BMW F20 F21 F22 F23 N55 M135i M235i
    BMS Intake Ansaugung BMW F20 F21 F22 F23 N55 M135i M235i: Biete hier ein neuwertiges Burger Motorsports Air Intake für einen N55 Motor an. Keine Beschädigungen. Läuft einwandfrei. Filter wurde frisch...
  4. SUCHE M235i N55 Air Intake Ansaugung BMS o.Ä.
    SUCHE M235i N55 Air Intake Ansaugung BMS o.Ä.: Suche für meinen BMW M235i N55 ein Ansaugsystem bzw. Air Intake wie z.B. das von BMS oder was ähnliches. Bitte mal alles anbieten mit Bildern und...
  5. PP-Intake 130i / 125i
    PP-Intake 130i / 125i: http://www.ebay.de/itm/BMW-Performance-Lufteinlass-System-Air-Intake-Luftfilter-1er-130i-125i-/271393495927?pt=DE_Autoteile&hash=item3f30501b77
