[E87] How to solve BMW DPF warning light problem
Diskutiere How to solve BMW DPF warning light problem im BMW 118d Forum im Bereich Informationen zum 1er E-Modell 2004-2013; I hope someone can translate the below into German. When this light start showing up on your dashboard 10 min. after every engine starts, the dpf...
  1. #1 BER, 12.06.2012
    BER
    BER 1er-Interessent(in)
    12.06.2012
    05/2007
    When this light start showing up on your dashboard 10 min. after every engine starts, the dpf regeneration system has already been automatically disabled due to high exhaust back pressure, subsequent requests for generation will be ignored and hence driving at autobahn alone will no longer solve the problem.
    Taking your car to werkstatt/BMW will not solve the problem either as they tend to suggest cleaning the dpf /dpf replacement is the possible solution and at best, they will clear your fault memory "once" for some € and point you to the autobahn and you will soon be back to square one.
    *avoid using DPF cleaning additive, as they will do damage to your DPF and produces ashes in your filter (which cannot be burned away as opposed to soot)
    Here is how one might be able to solve it
    1. start refilling only with Aral ultimate /Shell V-power Diesel
    2. buy a USB K+DCan Interface from ebay (50€)
    3. install the latest Inpa/Ediabas into a win7/XP notebook (Inpa EA90X-200)
    4. take a co-pilot with you to the autobahn and maintain >= 160km/h at 6th gear (Temp before CAT should be close to 350-400 degree C <- check under motor section->DDE7N47->status->analog value 2)
    5. the co-pilot would then need to start deleting "repeatedly" the fault codes 480a/481a (reappearing in 3-10 seconds interval for 10 to 20 times) under inpa: e87->motor section->DDE7N47. (manually overiding the disabled regeneration)
    The fault codes will eventually stop showing up and at that point, the regeneration shall have already kicked in (temp after CAT rises to >= 500 degree C) and last for 10-15 minutes. The DPF data after regeneration can be read under the section "info memory" where the "filtered particulate matter at DPF" will be 0 m³/h.
    Congratulation :)
Thema: How to solve BMW DPF warning light problem
  1. 118d 480a 481a
  2. 480a 481a bmw
  3. inpa e87
How to solve BMW DPF warning light problem - Ähnliche Themen
  1. [E8x] Bmw Roadmap Professional 2017 Dvd Set SA609
  2. DPF ausgetauscht
    DPF ausgetauscht: Hallo zusammen, ich habe meinen DPF ausgetauscht bei meinem 120d Bj 2008 und danach das Auto ausgelesen keine Fehler oder ähnliches. Muss ich...
  3. [E8x] 135i Y-Rohr BMW Performance Auspuff
  4. BMW F20 Radsicherungsschrauben
  5. Neuer Nutzer mit erstem (gebraucht)BMW
