High Pressure Fuel Pump
Diskutiere High Pressure Fuel Pump im BMW 135i Forum im Bereich Informationen zum 1er E-Modell 2004-2013; Hello all, I'm sorry to write in English, but I don't speak German well enough to ask technical questions, or understand the answers. I'm also...
  1. #1 tinnemeneer, 29.07.2010
    tinnemeneer
    tinnemeneer 1er-Interessent(in)
    29.07.2010
    Hello all,
    I'm also sorry to bother the 1 series forum with a 3 series question, but this one seems more active than other forums.
    I am planning to buy a secondhand 335i but I've heard terrible stories about the HPFP on it. Most problems seem to excist in the USA though. This could be because they have 10% ethanol in the fuel there but also because BMW had to 'cheapen' the car for the USA so it will sell.
    I found some hits in this forum considering the HPFP, but like I said, my German isn't good enough to figure out if you guys were discussing the situation in the USA or that European 35i's are also having problems.
    Is the problem with the fuel pump bad enough to stay away from a 35i ?
    The reason I want to buy a 335i instead of a 135i is that I need the extra room. So please don't feel offended. :)
    Regards,
    Martin
    The Netherlands.
  2. #2 Alpina_B3_Lux, 29.07.2010
    Alpina_B3_Lux
    Alpina_B3_Lux 1er-Fan
    10.01.2010
    683
    For some more info about that problem in English I'd recommend you to go to the E90post forum. It's a regular topic over there, and although they're mostly US dominated the fuel pump is the same for the cars in Europe.
    We have seen less problems over here due to the better fuel quality, but it is still a recurrent problem. Still, should it prevent you from getting the 335i? I wouldn't say so - the fuel pump is not that expensive to replace after all. And the car is so much fun and easy to modify - the best engine that BMW has made for a long time (I'm talking about the N54 here, obviously).
    Alpina_B3_Lux
  3. #3 Catahecassa, 30.07.2010
    Catahecassa
    Catahecassa 1er-Guru
    20.03.2008
    9.917
    Hi, there is a known issue at BMW to replace tbe HPFP & adjust software to avoid further problems. Go for the 335i & enjoy the ride on the torque plateau ;)
  4. #4 tinnemeneer, 30.07.2010
    tinnemeneer
    29.07.2010
    Well, I want to figure out how bad the problem is before I make the decision to buy or not to buy the car.
    I used to have a Jeep Cherokee which had so much problems I became afraid to drive it.
    That also cost me a fortune in repairs, so that's another reason to know what I'm getting into.
  5. #5 Catahecassa, 30.07.2010
    Catahecassa
    20.03.2008
    9.917
    No fear necessary ... a switch to ne actual generation with software upgrade to reduce initial fuel pressure is mainly covered by BMW warranty and if not, its below 500EUR in total. The sympton is, that starting the car needs about 5x turnarounds on the engine or you get an error in display and power is limited to felt 150PS ... you can drive with the defect pump though, but exchange then would be highly needed. Mainly the fault is detected between 40-60tkm ...
  6. #6 tinnemeneer, 30.07.2010
    tinnemeneer
    29.07.2010
    Thank you. So there is a fix to the problem. That is great news. :)
    I'll make sure I check if that's done before I buy the car.
  7. #7 Catahecassa, 30.07.2010
    Catahecassa
    20.03.2008
    9.917
    take care & good luck!
  8. #8 Geronimo, 30.07.2010
    Geronimo
    Geronimo 1er-Fanatiker(in)
    15.01.2008
    4.479
    lo prometido es deuda - ich versteh dieses griechische gelaber einfach nicht ... *g*
High Pressure Fuel Pump - Ähnliche Themen
  1. [Verkauft] Original BMW Rückleuchten LED HIGH links & rechts Top Zustand für 1er F2x
  2. [Verkauft] Original Blacklines High Rückleuchten E81/87
    Original Blacklines High Rückleuchten E81/87: Moin, aufgrund eines Fahrzeugwechsels biete ich euch meine Original BMW Blacklines High für den E81/87 zum Kauf an. Die Rückleuchten sind in einem...
  3. Verkaufe orginale E81/87 high Rückleuchten
    Verkaufe orginale E81/87 high Rückleuchten: Servus, Ich habe ein satz orginale Rückleuchten zu verkaufen, da ich auf black edition umgerüstet habe. Rückleuchten sind gebraucht aber optisch...
  4. [Verkauft] 335i HIGH Tacho + variables Drehzahlband + weiße LEDs
    335i HIGH Tacho + variables Drehzahlband + weiße LEDs: Hallo, verkaufe ein umgebautes Kombiinstrument vom 335i (e9*) mit bereits weißen LEDs. Das KI hat ein variables Drehzahlband, das heißt wenn der...
  5. Seltsames Verhalten iDrive Controller "High" nach Einbau BMW Integrated Navigation
    Seltsames Verhalten iDrive Controller "High" nach Einbau BMW Integrated Navigation: Hallo, ich habe mir im August in meinem F20 die "BMW Integrated Navigation" nachrüsten lassen. Mit der Navigation bin ich zufrieden allerdings...
