Fitting a plastic Air Temp Sensor to a silicone Samco hose?
Diskutiere Fitting a plastic Air Temp Sensor to a silicone Samco hose? im Tuning E8x Forum im Bereich Informationen zum 1er E-Modell 2004-2013; Hello all, I am replacing my intercooler on my 120d e87 with a 335d one, which is bigger and has also bigger piping. So I'm making a custom pipe...
  1. #1 beckerplast, 16.05.2015
    beckerplast
    beckerplast 1er-Fahrer(in)
    12.09.2012
    79
    Hello all,
    I am replacing my intercooler on my 120d e87 with a 335d one, which is bigger and has also bigger piping. So I'm making a custom pipe from the IC towards the intake manifold.
    It will be constructed of inox straights and silicone hose (Samco) 45 degree bends.
    The problem is the intake air temp sensor.
    At the moment it is mounted in the original plastic pipe, and has a plastic base.
    If it was a metal base /and sensor, I would weld a base onto an inox straight pipe and simply plug the sensor in the newly created base.
    Since its made of plastic, I can't fit it in inox piece of hose. Is it possible to securely fit it into the rubber part of the new hose? It has to withstand 2 bar of pressure. Can I glue it in?
    Thanks for the answer. ...
  2. heng9r
    heng9r 1er-Profi
    04.02.2014
    2.596
    621
    Vechta
    04/2008
    Henrik
    Wrong Area :eusa_naughty: only for 1-series modifications
  3. #3 beckerplast, 16.05.2015
    beckerplast
    12.09.2012
    79
    also, das IST aber eine 1er modification! :)
    In welcher Bereich sollte ich die Thema einstellen?
  4. #4 Maulwurfn, 16.05.2015
    Maulwurfn
    Maulwurfn 1er-Guru
    14.07.2011
    8.948
    276
    Helgoland
  5. #5 beckerplast, 16.05.2015
    beckerplast
    12.09.2012
    79
    Danke ;)
  6. #6 TheAxiom, 05.06.2015
    TheAxiom
    TheAxiom 1er-Interessent(in)
    26.03.2014
    11
    Florida, USA
    It works, Rev Motoring makes a hose for the N52. (on Ebay)
Fitting a plastic Air Temp Sensor to a silicone Samco hose? - Ähnliche Themen
  1. [Verkauft] RDCi rdc Sensoren original BMW 1er 2er
    RDCi rdc Sensoren original BMW 1er 2er: Habe noch einen Satz original rdci Sensoren hier. Sie waren bei meinen neuen gebrauchten Felgen dabei, aber ich brauche sie nicht. [ATTACH]...
  2. [E82] SOUND? 123d Performance (no Downpipe, Air Filter, LLk, Miltekand Optimate)
  3. [Verkauft] Biete iPad Air 2
    Biete iPad Air 2: Hallo biete hier mein iPad Air 2 16GB an. Das Gerät ist 2 Jahre alt. Es hat unser Haus nie verlassen. Das iPad war Teil eines...
  4. Endlich haltbare Alternative zum NOx Sensor
    Endlich haltbare Alternative zum NOx Sensor: Wer es noch nicht wusste: Hier gibt es eine Alternative zum ständigen Wechsel der NOx Sensoren im N43 und N53:...
  5. [E87] Massenproblem oder irgend ein Steuergerät am A....?
    Massenproblem oder irgend ein Steuergerät am A....?: Hallo Liebe 1er Gemeinde... war lange nicht da, da ich meinen alten 1er verkauft habe. Seit ca. 2 monaten bin ich wieder "glücklicher" Besitzer...
