F15 und F30 Frage aus Canada
Diskutiere F15 und F30 Frage aus Canada im Allgemeines zum BMW 2er F2x Forum im Bereich Informationen zum 1er und 2er F-Modell ab 2011; Hallo zusammen, Ein bekannte hat eine Frage die ich auch nach benötigung der Suche nicht einordnen konnte. Bitte dieses Thema in den...
  1. #1 Rob 116i F21, 22.06.2014
    Rob 116i F21
    Rob 116i F21 1er-Fahrer(in)
    24.12.2013
    108
    (NL)
    09/2018
    Rob
    Bitte dieses Thema in den richtigen Bereich verschieben wenn ich hier absolut falsch bin.
    Die Frage lautet so:
    So the fan on my F15 and F30 turn on everytime i turn on the vehicle, regardless of the previous status (ON/OFF) that it was before shutting off the engine...
    My 4 months old F15 wasn't like this when we bought it (neither was my previous F25). The fan would remain off if the last status was off before shutting off and vise-versa. But ever since the reprogramming done by the dealership because they wanted to change a part (not to mention the quality concern on a 2 weeks old $90,000 vehicle that needed a part replacement!), it now performs like this... dealership tells me the new firmware/softwares are like this and there's nothing we can do!
    What is the benefit of this and why is this functioning in such manner?...Everytime I turn on the vehicles, a burst of unwanted air blows into my face even if the fan was off previously? not to mention the pressure it imposes on the engine when the car is turned on...
    The service manager tells me, it has to do with detecting the amount of cabin condensation and safety measure...really??? so every time, even after 5 min of car shut down???
    It is like having your windshield wipers or radio turn on everytime you turn on your car! Is this normal?
    ...technical savvy folks, any comment or resurrection?
  2. deftl
    deftl 1er-Süchtling
    10.02.2012
    10.731
    872
    just the same with F20 since the beginning of Serial car production.
    ther will be one singel Option, reprogramming outside the BMW Company....BMW will and can NOT Change this behaviour....
    have a look at coding orums in the US site or the theme inside this Forum....
    I personally set teh A/C all the time ON and in AUTO function at the lowest auto-fan mevemnet, so it seems usable in summer and wintertimes.....fan rpm can then set higher, if necessary....
  3. deftl
    deftl 1er-Süchtling
    10.02.2012
    10.731
    872
    there will be one singel option, reprograming outside the BMW Company....BMW will and can NOT change this behaviour.
    have a look at coding forums in the US site or the theme inside this forum....
    I personally set teh A/C all the time ON and in AUTO function at the lowest auto-fan movemnet, so it seems usable in summer and wintertimes.....fan rpm can then set higher, if necessary....
  4. #4 dacno1982, 22.06.2014
    Zuletzt von einem Moderator bearbeitet: 22.06.2014
    dacno1982
    dacno1982 Guest
    Um dir helfen zu können, sollte man zumindest den verbauten Motor wissen.
    Alles andere ist Kaffeesatzleserei, wie wir hier in Deutschland sagen :icon_cool:
    Beim 35i Motor gibts teilweise Probleme mit dem Kühler / Ventilator. Das du nichts mit der Suche gefunden hast, wundert mich nicht, denn das ist das 1er/2er Forum :wink:
    Bei den Canada / US Modellen sind sowieso einige Dinge, grade bei der Kühlung anders, nennt sich "Heisslandausführung".
    Bei der "Aircondition" läuft der Lüfter auch. Läuft er lange nach, nach dem Motor-aus ?
    Ist ja bei euch kein großes Problem, die Amis und Canadier bekommen ja serienmäig 4 Jahre / unlimited Mileage Garantie...
    Das ganze in meinem besten Schul-Englisch: :mrgreen:
    --- If we should help you, we need to know the engine, at least. The US / Canadian Versions of all BMW Cars are different to the german-Version, they are equiped with a different Engine-cooling and some other stuff, called "Hot Country Version"
    Maybe it comes from the aircondition, the fan runs always when aircondition is on high output. Thats normal: Did the fan stopps imediately after engine turn off ? Try out to put the AC off.
  5. #5 misteran, 22.06.2014
    misteran
    misteran 1er-Guru
    25.02.2009
    8.320
    942
    Bad Kreuznach
    Geht doch darum, dass die Klima/Heizungsanlage nicht ausbleibt, wenn diese zuvor ausgeschaltet wurde, beim Motorstart.
    Mich stört das verhalten auch. Man kann zwar was codieren, dann bleibt das ganze System immer aus beim Motorstart, auch wenn vorher das System an war.
    Abgesehen von seltsamen nebeneffekte die ich hatte ... habs dann wieder auf Serie codiert, wo immer das System angeht.
    Ich finds auch blöd. Beim Vorgänger war es nicht so. Würde es auch besser finden, wenn einfach der letzte Status des System angewendet wird beim Motorstart.
    Denke hat einfach was mit dem Comfort Modus zu tun in dem der Wagen startet. BMW sieht es wohl so, im Comfort Modus soll es laufen.
  6. #6 Rob 116i F21, 23.06.2014
    Rob 116i F21
    24.12.2013
    108
    (NL)
    09/2018
    Rob
    @ Alle,
    Schon mal recht herzlichen dank für die Informationen.
    Ich werde für David (dacno1982) mal fragen welcher Motor es betrifft.
    Das von Deftl werde ich auch mal durchschicken.
    Und von misteran werde ich mal übersetzen und als möglichkeit erwähnen.
    Gruss Rob
F15 und F30 Frage aus Canada - Ähnliche Themen
  1. SCC Spurverbreiterung VA 20mm HA 30mm 5x120 BMW F20 F30 F31 F10 F11 Spurplatten
    SCC Spurverbreiterung VA 20mm HA 30mm 5x120 BMW F20 F30 F31 F10 F11 Spurplatten: [IMG] EUR 139,00 End Date: 19. Mrz. 15:07 Buy It Now for only: US EUR 139,00 Buy it now | Add to watch list Weiterlesen...
  2. Wagner Ladeluftkühler Evo 1 für F20 F30
    Wagner Ladeluftkühler Evo 1 für F20 F30: Hallo, suche o.g. LLK Performance oder Competition ist zweitrangig- hauptsache mit Zulassung. Wenn ihr was passendes habt gerne melden. Danke...
  3. 4 BMW Reifendrucksensoren RDCi 433 MHz 1er F20 3er F30 X1 X2 X5 F15 6855539 TOP
    4 BMW Reifendrucksensoren RDCi 433 MHz 1er F20 3er F30 X1 X2 X5 F15 6855539 TOP: [IMG] EUR 69,00 End Date: 28. Feb. 16:30 Buy It Now for only: US EUR 69,00 Buy it now | Add to watch list Weiterlesen...
  4. Original BMW RDKS-Sensor // 6856209 // 1er F20/F21 / 2er F22,F23 / 3er F30,F31
    Original BMW RDKS-Sensor // 6856209 // 1er F20/F21 / 2er F22,F23 / 3er F30,F31: [IMG] EUR 45,99 End Date: 07. Mrz. 16:00 Buy It Now for only: US EUR 45,99 Buy it now | Add to watch list Weiterlesen...
  5. BMW F20 F22 F30 F31 F32 F36 F15 Headunit EVO Navigation 6833995 id5/id6 1.106km
    BMW F20 F22 F30 F31 F32 F36 F15 Headunit EVO Navigation 6833995 id5/id6 1.106km: [IMG] EUR 799,00 End Date: 17. Mrz. 14:56 Buy It Now for only: US EUR 799,00 Buy it now | Add to watch list Weiterlesen...
