Electronic problems after disconnecting battery
Diskutiere Electronic problems after disconnecting battery im BMW M135i / M235i / M140i / M240i Forum im Bereich Informationen zum 1er und 2er F-Modell ab 2011; Hi, I installed the Awron display today. Everything went as described in the manual. Disconnected the battery for safety reasons (only the...
  1. Sinof
    Sinof 1er-Interessent(in)
    28.04.2014
    19
    I installed the Awron display today. Everything went as described in the manual. Disconnected the battery for safety reasons (only the "-"). Made all the connections to the CANBUS (only the red wire connection to the Awron cable had to be modified and soldered.) Reconnected the battery. Started the car and now the strange things I notice:
    No electric rear windows
    No Idrive
    No turning lights at the back
    Boot doesn't open
    No fuel level visible
    Drives perfectly, Awron works great (so the one connection I had to modify works).
    Is there a reset button?
    Thx
  2. DomMuc
    DomMuc 1er-Profi
    24.11.2012
    2.066
    114
    02/2013
    so you might used the wrong wires to connect or bustetd your REM ( RearElectricModule)
  3. Sinof
    28.04.2014
    19
    I double-checked the wires with the Awron manual => everything correct (if the manual is correct), and the apron functions as it should: all the numbers and figures are there and I can operate it with the speed control button.
    The REM module normally takes care of the sunroof too I think => sunroof works normal. Does the REM module takes care of the Idrive?
  4. Sinof
    28.04.2014
    19
    Apparently no problem at all => readout at the dealer and they bettered my connection of the wire I messed up and everything OK now.
    Awron display is great!!
  5. Roy
    16.07.2012
    5.715
    2.360
    Ulmen/ Eifel
    Congrats !!
    :daumen:
  6. Sinof
    28.04.2014
    19
    It amazes me now that the oil heats up quite fast. The picture here is from cold engine after 5 km.
  7. Regao
    Regao 1er-Fan
    28.05.2008
    638
    NRW
    ok sommer zeit zwischen 20 und 30 grad da geht es recht fix
    meine heizung macht schon nach nichmal nen kilometer warme luft
    im winter
    der kleine wird echt schnell warm
  8. #8 deftl, 21.06.2014
    deftl
    deftl 1er-Guru
    10.02.2012
    9.527
    471
    let me be sure:
    79°C engine oil, 99°C cooling water....?!
    i think this is correct, while I got similar results with my 118d using the secret menue function.
    so, what is irritating? how gets the water hotter than the engine oil? and, the warming of the engine oil circuit should be preference one, the rest of heating energy should be moved into the cooling circuit.
    ok, in wintertime it seem more reasoanbel to get this temp splitting: cooling water is warmed up in addition by electrical heating, only by the D engines, I engines miss this feature, I guess....
    is there a reasonable explanation?
    thanks!
    and looks nice! how long was the hardware inbuilding process?
    and how many money did you spend at least?
  9. Sinof
    28.04.2014
    19
    Eventually the oil gets hotter than the water. The water always heats faster, which is normal.
    It takes about 1-1,5h to build it in. Cost is about 700€.
  10. Flo_M2
    Flo_M2 1er-Fan
    18.10.2013
    966
    51
    Schweinfurt
    M2
    Coupé (F87)
    03/2016
    Flo
    First of all, the display looks great! :daumen: Can you tell me where you bought the display? The only german supplier I could find is Manhart!?
  11. STIG
    STIG 1er-Interessent(in)
    02.09.2014
    Österreich
    07/2013
    Mario
  12. Sinof
    28.04.2014
    19
    I bought it directly from Awron. You can find them on Facebook and just send them an email. :daumen:
  13. Regao
    Regao 1er-Fan
    28.05.2008
    638
    NRW
    hängt auch da,it zusammen das das wasser ein besserer wärmeleiter ist als öl darum wird es schneller warm
Electronic problems after disconnecting battery - Ähnliche Themen
  4. 118i 2006 bj Probleme?
  5. Steuerkette neu - seit dem nur Probleme
    Steuerkette neu - seit dem nur Probleme: Hallo 1er Freunde, seit dem vor 3 Mon. meine Steuerkette ern. wurde habe ich nur noch Probleme. Es fing schon damit an, dass die freie Werkstatt...
