Driving modes table (Fahrerlebnisprogramme)
Diskutiere Driving modes table (Fahrerlebnisprogramme) im BMW M135i / M235i / M140i / M240i Forum im Bereich Informationen zum 1er und 2er F-Modell ab 2011; After reading this tread and having my own experiences I tried to capture all changes that happen when you switch to a different driving mode in...
  1. #1 devio, 28.02.2015
    devio
    devio 1er-Interessent(in)
    16.06.2011
    After reading this tread and having my own experiences I tried to capture all changes that happen when you switch to a different driving mode in one table.
    For example I put a microphone on the exhaust to hear the operation of the valve of the left pipe. And for the shiftspeed I filmed the rev counter and synced them frame by frame in Adobe After Effects to see the differences in the speed of the needle (OMG what a nerd).
    What 'm currently not sure about is ADB-Sport, according to the manual it is only operational in DSC-OFF mode. And furthermore the Hard shift (lastschlag dämpfung off) and Engine Mapping as I cannot measure this objectively.
    I would like to hear your observations and please discribe how I can reproduce this on my car. I'll update the table as I gather more info. Feel free to comment in German I'll understand, probably, I'm Dutch. :)
    This the Excel spreadsheet:
    [URL="http://members.multiweb.nl/carlebur/Drivingmodes.xlsx[/URL]
    bay_2002 gefällt das.
  2. #2 dr.schuh, 23.03.2015
    dr.schuh
    dr.schuh Guest
    Great chart, thanks a lot! Complete and very clear overview of all characteristics affected by the drive modes. :daumen:
  3. #3 sYnergY, 23.03.2015
    sYnergY
    sYnergY 1er-Fahrer(in)
    23.07.2014
    144
    25
    D-47906 Kempen
    M140i xDrive
    12/2017
    Felix
    Impressive work, thank you so much! And what a relief it is to have all relevant information in one chart instead of having to browse through multiple threads concerning this topic.
    Hopefully, I will be able to contribute something to the chart in the near future.
    Best regards
    Felix
  4. #4 //Martin, 23.03.2015
    //Martin
    //Martin 1er-Fahrer(in)
    11.02.2014
    150
    Sprockhövel
    09/2013
    Thank you for sharing this spreadsheet!
  5. #5 M135ixA, 23.03.2015
    M135ixA
    M135ixA 1er-Interessent(in)
    15.01.2015
    49
    11
    Max
    Stunning work! Thanks a lot!
  6. #6 McDaniel, 25.03.2015
    McDaniel
    McDaniel 1er-Interessent(in)
    09.01.2015
    Holy cow, some serious commitment
  7. #7 McDaniel, 25.03.2015
    McDaniel
    09.01.2015
    So, did I got it right? If I am in sport mode drivetrain and chassis, above 20km/h, the exhaust valve is always open?
  8. devio
    16.06.2011
    No, only in 1st and 2nd gear. In 3rd gear and up the valve is only open when you apply throttle. But it opens even with the slightest amount of throttle.
    If you listen very carefully you can hear this: Drive (in SPORT D, C+D or +) just over 20km/h in 3rd gear, you will hear a very faint ‘bzzt’ sound coming from the rear when you release the throttle, the valve closes. Apply some throttle again and you will hear ‘bzzt’, the valve opens. If you let your car slow down off-throttle you will first hear the ‘bzzt’ sound when you release the throttle to slow down and then ‘bzzt’ again when you slow down further and pass exactly 20km/h, the valve is now open again below 20km/h.
    In the other modes it requires much more throttle to open the valve above 20km/h, and you can’t hear the ‘bzzt’ because of the engine sound.
  9. #9 misteran, 25.03.2015
    misteran
    misteran 1er-Guru
    25.02.2009
    7.763
    300
    Bad Kreuznach
    What does "Engine Mapping" mean?
  10. devio
    16.06.2011
    Motorenkennfelder
  11. #11 McDaniel, 25.03.2015
    McDaniel
    09.01.2015
    Thank you for the clarification.
  12. JB4
    JB4 1er-Interessent(in)
    04.11.2012
    15
    Bern (Schweiz)
    11/2015
    Thank you, very impressive :)
  13. BMWUA
    BMWUA 1er-Fanatiker(in)
    26.08.2008
    4.500
    53
    Nordeifel
    Ich habe mal die Zündzeitpunkt bei den verschiedenen Modi (beim M135i) geprüft und gesehen, daß im Sport/Sport+ später gezündet wird. Hier ist der Zündzeitpunkt bei um die 20-25° for OT. Hingegen läuft der Motor im Comfort/EcoPro Modus mit einem Zündwinkel von 30-35° (z.B. bei 120km/h im 6. Tempomat auf der Ebene). Richtig krass ist der Unterschied bei z.B. 90km/h im 2. Gang. Hier wird von fast 45°-50° in Comfort auf 20°-30° in Sport verschoben.
    Ab ca. 130/140km/h gleichen sich die Zündwinkel an und sind identisch. Bei 160 gibt es dann keine Unterschiede mehr.
    Die entsprechend spätere Zündung gibt auch den etwas kernigeren Klang im Sportmodus in der unteren Hälfte des Drehzahlbereichs. Oben klingt beides identisch, wie eben auch die Zündzeitpunkte sich nicht unterscheiden.
    Docter, #1er und sk156 gefällt das.
  14. #1er
    #1er 1er-Profi
    24.01.2015
    2.707
    1.241
    09/2016
    Sehr interessant :daumen: Hast du ne Quelle zum Lesen, interessiert mich schon. Hat der frühe Zündzeitpunkt "negative" Effekte bzw. wie wirkt er sich aus oder bringt er nur mehr Sound?
  15. BMWUA
    26.08.2008
    4.500
    53
    Nordeifel
    Nein, keine Quelle. Aber es gibt im Netz einige Doku zum N55-Motor. Hier musst Du mal suchen.
    Die Veränderungen zum ZZP habe ich selbst gemessen.
  16. sk156
    sk156 1er-Fan
    16.04.2015
    586
    497
    Heilbronn
    11/2015
    Weißt du auch wie sich das auf Verbrauch oder Leistung auswirkt?
  17. DomMuc
    DomMuc 1er-Profi
    24.11.2012
    2.065
    113
    02/2013
    warum wird diese tabelle alle 2 monate wieder gepostet ....?
  18. #18 Sixpack66, 14.02.2017
    Sixpack66
    Sixpack66 1er-Profi
    14.05.2015
    2.346
    1.171
    Sackeifel
    07/2014
    Ralf
    Weil immer wieder danach gefragt wird und einige nicht wissen wie man über die Suchfunktion fündig wird.
    Manchmal Faulheit, manchmal aber kommt man nur nicht auf den richtigen Suchbegriff.
    Wenn du andere, bessere, neuere Tabellen hast............................hier ist jede Menge Platz. :mrgreen:
Thema: Driving modes table (Fahrerlebnisprogramme)
  1. 1er forum
  2. m235 exhaust valve modes
  3. M140i chart driving modes
Driving modes table (Fahrerlebnisprogramme) - Ähnliche Themen
  1. Unterschied Aktive Geschwindigkeitsregelung mit Stop&Go-Funktion und Driving Assistent
    Unterschied Aktive Geschwindigkeitsregelung mit Stop&Go-Funktion und Driving Assistent: Guten Morgen, Bin gerade dabei mir einen 240iX zusammenzustellen. Dabei bin ich üder die diese beiden Ausstattungen gestolpert. Beim Driving...
  2. Verstärktes Schubumluftventil (DV+) (~= BOV-Mod-Ersatz beim N55 im F2x)
    Verstärktes Schubumluftventil (DV+) (~= BOV-Mod-Ersatz beim N55 im F2x): Ich lese hier im Forum relativ wenig zu diesem Teil. Zum vergleichbaren BOV-Mod bei den E8x-Modellen liest man schon deutlich mehr, dieser...
  3. ICE watch | BMW M Driving Experience Edition
    ICE watch | BMW M Driving Experience Edition: Servus zusammen, zum Verkauf steht eine ungetragene ICE watch in der BMW M Driving Experience Edition in Orginalverpackung. Dieses Modell gibt...
  4. Orig. BMW1er-Radio Mod. AUDIO
    Orig. BMW1er-Radio Mod. AUDIO: [IMG] EUR 25,00 End Date: 14. Mai. 12:26 Buy It Now for only: US EUR 25,00 Buy it now | Add to watch list Weiterlesen...
