Chip 123d and SERVICE BMW??????
Diskutiere Chip 123d and SERVICE BMW?????? im BMW 123d Forum im Bereich Informationen zum 1er E-Modell 2004-2013; Hello, I have readen some Yours post and as far as I see there is a lot of bmw 123d with chip. The problem is that I don't understand German...
  1. #1 wojtek22, 17.10.2008
    wojtek22
    wojtek22 1er-Interessent(in)
    04.11.2007
    12
    PL
    Hello,
    I have readen some Yours post and as far as I see there is a lot of bmw 123d with chip. The problem is that I don't understand German language.
    That's why I have some questions about it. I can ask only You because in Poland there is any 123d with chip.
    1.Could You answerd me what is the difrence between 123d (standard) and 123d (chiped) I ask You about diffrence in accelerator and in fuel? Before 123d I had a Golf IV TDI and I chiped it and there was really big diference between.
    2.What about clutch and gearbox in yours chiped 123d?? Do You have any problem with yours chiped cars?
    3. And the last questions is What about it thinking SERVICE BMW. Becouse I hav paid a lot of money to have a guarantee on my car and free servis for 3 years. As I ask in my Service station they said that if I make a chip in 123d I will lose my guarantee and free servise. IS it true???
    Thank's for answearing
    And Sory for my English
    Best regards
    wojtek
  2. #2 fastwriter, 17.10.2008
    fastwriter
    fastwriter 1er-Fahrer(in)
    29.05.2008
    136
    Düsseldorf
    Question 1 & 2 - I cannot answer
    Question 3: Yes it is true: You will loose your warranty (Guarantee as you wrote). It is the same over here in Germany. If you are lucky your dealer will not notice that there is a modified chip in your motor management system. But there is always a risk he will notice - and then you're in trouble.
    Best regards and greetings over to Poland
    (and by the way: the 123d has enough power - I changed it for a 3.0-Gasoline-Engine with 231 HP and I don't miss power at all)
  3. #3 fastwriter, 17.10.2008
    fastwriter
    29.05.2008
    136
    Düsseldorf
  4. #4 wojtek22, 17.10.2008
    wojtek22
    04.11.2007
    12
    PL
    Thank's for your answer.
    I think that 123d is fast but not as fast as I want it to be.
    Specialy on overcrowd polish roads. Where we have to overtake TIR on really crowded roads we need a really more power.
    I think that I should check the power of my car in Tuning Company.
    Best regards from Poland
  5. pkm680
    pkm680 1er-Fahrer(in)
    25.08.2008
    52
    NRW
    hallo wojtek,
    to answer your first and second question:
    the normal power is about 204hp and 400NM of torque
    chipped it will be roughly round about 250hp and 500NM
    i chipped my 123d via digitech and i am absolutely happy with it
    my car has 250hp and 519nm on the paper
    the fuelconsumption is going to shrink when you are going to drive like you did before, the loss is about -0,5 liters
    the fact with the guarantee must not be true because most dealers and maintenance shops are not able to check if your car has beeing chipped.
    but if you have troubles and they sent your motormanagement-unit to munich they are able to proof and in this case they will not pay any damages on your motor the clutch, gearbox and shafts.
    my clutch is absolutely fine and i drove more than 15000km with the chip and as far as i know bmw granted torque to over 500NM for the gearbox so that i do not see any problems with that.
    last but not least i would suggest you to take a good tuner to avoid any problems, your motorunit is a so called edc 17 series which is not very easy to program and most tuners are not able to do it. sometimes problems could occure and the unit is going to be destroied during programming process.
    so take care of a real good tuner which is able to get a new one if necessary.
    after the tuning you will definetly feel the increase of the power especially during acellaration in high speeds
    regards
  6. #6 wojtek22, 08.01.2009
    wojtek22
    04.11.2007
    12
    PL
    hallo
    tkank's pkm680 for Your answer,
    I'm still thinking about the chip.
    I will decide to do it after winter, becouse now a condition on roads are really bad.
    regards.
  7. #7 nightperson, 08.01.2009
    nightperson
    nightperson 1er-Guru
    07.11.2005
    6.927
    Kaarst
    I was also considering to chip tune my 123d because of the very annoying max. speed issue. But luckily I decided to leave it as it is, since I got a new engine recently because of leaking cooling liquid. If I had "optimized" my car the costs for the new engine were on me :shock: I owned three chiped tuned cars so far, but this time I'm sure I took the right decision :wink:
    Cheers,
  8. #8 wojtek22, 16.01.2009
    wojtek22
    04.11.2007
    12
    PL
    And what is Your's car V-max speed?
    One time I drive over 250km/h, but it's happened only once.[/img]
  9. RWFG
    RWFG 1er-Profi
    13.10.2007
    2.624
    NRW
    With the old software the max speed of the 123d was limited to real 234 km/h. That should be approximately 246 km/h on your speedometer.
    With the new software speedometer 250 km/h on a straight flat autobahn, which is 238 km/h in reality, as announced in the car's papers.
    Downhill my car reaches 242 km/h in reality and 254 km/h on the speedometer. But that happens only on descents.
    This is why Tuning can't really increase the Top-Speed of your car. The car is now limited at 4.850 revs per minute, which is set at 254 km/h at your speedometer.
  10. #10 nightperson, 17.01.2009
    nightperson
    07.11.2005
    6.927
    Kaarst
    It's exactly as Jens wrote, the max. speed you can reach with an unchiped car is 247 km/h (pre-update) respectively 254 km/h (update) on the speedo. The latter I have only achieved a few times with tailwind or on descents. People who already have tuned their 123d's reported they couldn't increase max. speed but only acceleration.
    Cheers,
Thema: Chip 123d and SERVICE BMW??????
  1. bmw 123d chiped
Chip 123d and SERVICE BMW?????? - Ähnliche Themen
  1. BMW M Performance Parts im Leasing
  2. BMW M Performance Parts im Leasing
  5. [F21] Original BMW Rückleuchten LED HIGH links & rechts Top Zustand für 1er F2x
