Bmw f21 water pssenger side problem
Diskutiere Bmw f21 water pssenger side problem im Allgemeines zum BMW 1er F2x Forum im Bereich Informationen zum 1er und 2er F-Modell ab 2011; hello, I have a problem in my bmw f21, today dismounting to install pdc front, I have met with the passenger side carpet full of water, someone...
  1. r0b3r
    r0b3r 1er-Fahrer(in)
    12.05.2016
    116
    hello, I have a problem in my bmw f21, today dismounting to install pdc front, I have met with the passenger side carpet full of water, someone can help me? not where it enters the water.
    no water coolant is water or wipers.
  2. deftl
    deftl 1er-Süchtling
    10.02.2012
    10.836
    903
    pure water? wipers water with some cleaning additives? and only UNDER the carpet? at this Position it would be (expection) normally water of the heating circuit. but this will be with colour and BMW glycerol additon. typically the carpet get then wet....
    how much water is it? only spare Drops or more? thinking on not completely closed window or door and rain driving. no idea which otherwise would explain pure water....
    can you test the pH of the water?
  3. r0b3r
    12.05.2016
    116
    Hello, wet part is under the carpet as seen in the images, foam carpet wet enough but not puddle of water.
    I've never changed glass so I rule out that between the glass.
    Only lower floor carpet is wet foam driver, top not only what you see in picture, next duct ventilation.
    I am not able to see where it enters the water, the smell is water moisture.
  4. deftl
    deftl 1er-Süchtling
    10.02.2012
    10.836
    903
    must be related with door closing or door seals....no other idea. otherwise there must be an underbody damage/leak ....
    all the cases reported here with simlar wet carpets were related to a leaking heating circuit (heat excanger Connection). this is a known purpose....
    sorry, no other ideas. dry it, observe it. if it is related to any leak, you
    • will get it back wet...
  5. r0b3r
    12.05.2016
    116
    You can teach it comes with the most common cases around here for? to review the same case? They detected plain water?
    I initially thought it was water drain AC but can not find.
  6. deftl
    deftl 1er-Süchtling
    10.02.2012
    10.836
    903
    AC water drain you can find under the car plain water. if it stays dry after a long AC working period (have a look in the Garage) it could be a hint in this Direktion.
    if you have indeed PLAIN water, it is not possible to come from the heating circuit. but test the pH...only smelling (brrrr)....will not clear enogh.
  7. r0b3r
    12.05.2016
    116
    I've tried car AC good time and does not drip down the car in the garage, so I suspect that may be draining AC, rain or entry into car (drain plugs although it is very difficult or something similar.)
  8. #8 deftl, 12.05.2016
    deftl
    deftl 1er-Süchtling
    10.02.2012
    10.836
    903
    http://www.realoem.com/bmw/enUS/showparts?id=1E32-EUR-01-2014-F21-BMW-120d&diagId=64_1878
    check Position 4.....
    you have to remove pos 2:
    http://www.realoem.com/bmw/enUS/showparts?id=1E32-EUR-01-2014-F21-BMW-120d&diagId=51_9123
    if there is a broken connction you will get the AC condensating water probably under the carpet....viola?!
    you can choose left or right Hand drive in the BMW parts table....not sure, what you have:nod:
  9. r0b3r
    12.05.2016
    116
    I have removed cap number 2 link to send me, but I see part 4, where in this?
  10. deftl
    deftl 1er-Süchtling
    10.02.2012
    10.836
    903
    you are lookin in direction 9 top of. left of 9 ist the microfilter housing. you have to go right. not sure, if there ist allready simple Access to the water/air condense pipe. you have to find ring 5 and check for water/liqide. 4 or 6 will be the end in the underbody.
    if ther is a leak in the reagion, you will find water (after AC action!)....
  11. r0b3r
    12.05.2016
    116
    I will review it, I will also raise driver's side if also has water and check what you say, that more points could review?
    when fix it, also I have to change the front carpet that smells rotten, number 1 link
    It is very difficult to change it? I must disassemble?
  12. r0b3r
    12.05.2016
    116
  13. deftl
    deftl 1er-Süchtling
    10.02.2012
    10.836
    903
  14. r0b3r
    12.05.2016
    116
    Number 1 photo :
  15. deftl
    deftl 1er-Süchtling
    10.02.2012
    10.836
    903
    no1 is the front Plastik Body comtaining Drivers an co-Drivers side.....not sure, wehre to find the carpets. I suggest, the floor covering Body ist WITHOUT any carpets....
  16. r0b3r
    12.05.2016
    116
    Number one is carpeted front driver's side and passenger that is what I want change
  17. r0b3r
    12.05.2016
    116
    My car:
    Enviado desde mi iPhone utilizando Tapatalk
  18. deftl
    deftl 1er-Süchtling
    10.02.2012
    10.836
    903
    i suggest for the smell Problem first a Ozon Treatment:
    https://www.redozone.de/de/Ozongeraete/Ozongenerator-RZ-3500T.html
    the car and carpets have first to be dried! absolutly dry (use Ventilation and air heating in combination). Ozon Treatment must be in a secure and closed room (Garage). Keep animals and children away. Ozon Treatment over night, Ventilation in Addition inside the car will perform better. (Windows closed) 12h Ozon, 12h fresh air Windows open!), 12h Ozon, 24h fresh air. if necessary repeat it after some weeks....
    a bit time consuming, but less expensive (? see part costs!). Maby you have one with Ozon Generator nearby?! The Generator has to be porwerfull like the above link.
    Ozon kills all organic components of bacteria or mycorhizza smell......
    dont breath Ozon in high doses!
    i got the smoke smell of burned plastic away by this method after the additional electrical heater (inside AC block) flamed out....
  19. deftl
    deftl 1er-Süchtling
    10.02.2012
    10.836
    903
    is this the complete AC box/case? left side bowe Looks like the filter box? what marking the red circle? i cnnot zoom in to see the plastic components in higher Resolution.
  20. r0b3r
    12.05.2016
    116
    I am Spain, I would like to solve and change complete carpet front and ozonator, but not as exchange? photo plastic module that is ac
Bmw f21 water pssenger side problem - Ähnliche Themen
  1. Original BMW 1er F20 F21 Winterreifen Kompletträder Satz RDKS Räder GoodYear
    Original BMW 1er F20 F21 Winterreifen Kompletträder Satz RDKS Räder GoodYear: [IMG] EUR 179,00 End Date: 13. Sep. 23:17 Buy It Now for only: US EUR 179,00 Buy it now | Add to watch list Weiterlesen...
  2. 19 zoll MM02 Felgen für BMW 1er E81 E82 E87 F20 F21 M135i M140i M Performance
    19 zoll MM02 Felgen für BMW 1er E81 E82 E87 F20 F21 M135i M140i M Performance: [IMG] EUR 486,75 End Date: 06. Sep. 15:52 Buy It Now for only: US EUR 486,75 Buy it now | Add to watch list Weiterlesen...
  3. BMW 1er F20 F21 3er F30 F31 Rechner Champ 2 Navi Bussines
    BMW 1er F20 F21 3er F30 F31 Rechner Champ 2 Navi Bussines: [IMG] EUR 109,00 End Date: 01. Sep. 20:09 Buy It Now for only: US EUR 109,00 Buy it now | Add to watch list Weiterlesen...
  4. Original BMW Winterräder Winterreifen BMW 1er F20 / F21 & 2er F22 / F23
    Original BMW Winterräder Winterreifen BMW 1er F20 / F21 & 2er F22 / F23: [IMG] EUR 399,00 End Date: 13. Sep. 15:25 Buy It Now for only: US EUR 399,00 Buy it now | Add to watch list Weiterlesen...
  5. Winterkompletträder 388 Radialspeiche 18 Zoll BMW 1er F20 F21 2er F22 F23
    Winterkompletträder 388 Radialspeiche 18 Zoll BMW 1er F20 F21 2er F22 F23: [IMG] EUR 1.299,99 End Date: 13. Sep. 17:31 Buy It Now for only: US EUR 1.299,99 Buy it now | Add to watch list Weiterlesen...
