B58 weird noise under the hood
Diskutiere B58 weird noise under the hood im BMW M135i / M235i / M140i / M240i Forum im Bereich Informationen zum 1er und 2er F-Modell ab 2011; Hi guys, can you hear this noise ? Not the clicking, but the buzzing, lower frequency, noise. It's coming from this area, I can also hear it with...
  1. #1 luke7110, 01.02.2020
    luke7110
    luke7110 1er-Interessent(in)
    17.01.2020
    France
    M140i xDrive
    It's coming from this area, I can also hear it with the engine cover on and closed bonnet.
    I'm unable to locate it precisely, but it looks like it's near the fuel pump, on the right.
    I begun to hear it one month ago, I think it didn't changed since then.
    I can hear it right after I start the car, with cold or hot engine, and it silents right when I press the ignition button to shut off the engine, like a fraction of a second before the engine.
    I went to the dealer for the first oil change a few weeks ago, they told me it's the B58 normal engine noise... But I'm not convinced ...
    A guy from UK suggest to look for a loosen heat shield, but I'm not sure where to look.
    Another guy told me he had the same noise on his m135 (N55) and dealer fixed it with a new valvetronic servomotor, but on the B58 the servomotor is located on the opposite side of the fuel pump.
    What you guys think ? Ever heard this before ?
B58 weird noise under the hood - Ähnliche Themen
  1. B58 Motorproblem
    B58 Motorproblem: [M140i Handschalter] Ich habe seit heute leider ein Problem an meinem Motor. Ich habe es schon beim Anlassen bemerkt, dass er wesentlich höher...
  2. JB4 B58 mit Bluetooth
    JB4 B58 mit Bluetooth: Hallo, Ich würde eine JB4 Burger Motorsport Box für den B58, gerne mit dem Bluetooth Adapter suchen. Viele Grüße Marco
  3. [F20] Akra für 140i bzw. B58
    Akra für 140i bzw. B58: Moin, biete Akra EvolutionLine für B58, Anlage war rd. 8500KM verbaut. Achtung, Endrohre sind Custom aus 88,9mm Edelstahlrohr in blank, diese...
  4. B58 Stage 2 welche Zündkerzen ?
    B58 Stage 2 welche Zündkerzen ?: Habe gehört das mit Stage 2 die supra oder M3/M4 Zündkerzen besser funktionieren als die Serien Kerzen. Weiß jemand mehr und hat Erfahrungen damit?
  5. [F2x] B58 Ansaugung mit Resonator Stopfen
    B58 Ansaugung mit Resonator Stopfen: Moinsen, ich habe die B58 Ansaugung geöffnet und Metallstopfen angefertigt. Jetzt möchte ich sie aber abgeben. Die Stopfen sollten noch verklebt...
