[E87] 120d/177hp/Torque app catalytic temperature
Diskutiere 120d/177hp/Torque app catalytic temperature im BMW 120d Forum im Bereich Informationen zum 1er E-Modell 2004-2013; Hi. Could someone check, with Torque android app, what is the value of "Catalytic temperature (bank 1, sensor 1)"? I want to catch when the DPF...
  1. polkpo
    polkpo 1er-Interessent(in)
    07.03.2015
    I want to catch when the DPF regeneration is running, but the value for me is "-40°C". I haven't any error code.
    Thanks in advance.
  2. Anzeige
  3. polkpo
    07.03.2015
    I have the same temperature (-40°C) from one reading from BMWhat, tomorrow I'll write here the exact name of the BMWhat parameter.
    Is anyone here using Bluetooth OBDII adapter to read the error codes, monitor parameters and codding the car?
    P.S. sorry for the language, but neither German or English are my native languages.
  4. #3 WhiteWolf, 07.03.2015
    WhiteWolf
    WhiteWolf 1er-Fanatiker(in)
    07.04.2011
    3.107
    253
    Landsberg/Lech
    04/2006
    I use BMWhat and Torque.
    Next Week i can look for the Caatalytic temperature...
  5. polkpo
    07.03.2015
    Hi, the value in BMWhat is:
    "Exhaust gas temperature before particulate filter - corrected value" and it is -40,052643°C
    Thank you WhiteWolf, I'm worried about this temperature sensor.
  6. #5 WhiteWolf, 09.03.2015
    WhiteWolf
    07.04.2011
    3.107
    253
    Landsberg/Lech
    04/2006
    But I Think, exact this Sensor is defekt at my car, too.
    I´ll write you tomorrow :winkewinke:
  7. #6 WhiteWolf, 10.03.2015
    WhiteWolf
    07.04.2011
    3.107
    253
    Landsberg/Lech
    04/2006
    So, I have Checked the temperatures.
    My fault is the Temperature Sensor before catalysator.
    I would check your temperatur sensor. I´m not sure, but it could be, that this sensor is part of the requirements to clean you particular filter.
    If you have BMWhat, you can check the particular filter.
  8. polkpo
    07.03.2015
    I've asked the BMW dealer here, and he told me: "if there isn't an error, it's OK, this -40°C value is nothing abnormally". I assume that this may be true, as some cars have separate catalyst and DPF, and some have them in one body. I think that 1er have both filters in one body.
    But I still think, that if you have normal values for this, and the cars are the same, why I'll have such a strange value? Something should be wrong.
    In Torque app it's: "Catalytic temperature (bank 1, sensor 1)"
    In BMWhat two values are -40C:
    1)"Exhaust gas temperature before particulate filter - corrected value"
    2)"Exhaust gas temperature upstream particulate filter"
    The regeneration is still working, but I think that the soot (rußmenge) is growing fast, around 10g/100km.
    What are the values for this 3 parameters?
    Do you have some DPF regeneration issues with the defect temperature sensor before catalysator? Are you going to replace it?
  9. #8 WhiteWolf, 11.03.2015
    WhiteWolf
    07.04.2011
    3.107
    253
    Landsberg/Lech
    04/2006
    No, I haven´t any Problems, so i don´t replace this sensor. This Sensor is broken since ~2 years.
    With BMWhat you can watch your soot and the regeneration status very good. The Regeneration still works great, and the soot is in the normal range.
  10. Anzeige
  11. polkpo
    07.03.2015
    Thank you WhiteWolf. The regeneration seems to be fine. I'm not sure if the soot is growing faster than it should. I'll try to monitor this.
    I'm attaching some data from BMWhat parameter log. This 188km after the regeneration are from extra-urban driving on high revs (3000-5000) and the soot is 13.5 gr. it was 0 gr right after the regeneration. This days I'll drive mostly in the city, so I'll give some data of the soot mass growing.
  12. polkpo
    07.03.2015
    After around 100 km of urban driving:
120d/177hp/Torque app catalytic temperature - Ähnliche Themen
  1. Frage zum 120d (N47D20)
    Frage zum 120d (N47D20): Hi, ein Freund, der nirgends angemeldet ist, hat nen 320d Fxx Kombi (Schalter) mit dem vorgenannten Motor und beklagt, dass das Auto bei exakt...
  2. Paar Fragen zu diversen sensoren bzg. wassertemperatur, ladeluft temperatur
    Paar Fragen zu diversen sensoren bzg. wassertemperatur, ladeluft temperatur: Hey Leute Ich fahre einen 123d und hätte mal paar Fragen, die mir vll wer beantworten kann. Frage 1: Ich habe in der Front hinter den Nieren, so...
  3. [E81] 120d PP-Kit Baujahr 2011
    120d PP-Kit Baujahr 2011: Hallo in die Forumsrunde, ich verkaufe meinen gepflegten 120d E81 mit M-Sportpaket und Performance Power Kit da etwas neues ins Haus kommt. Der...
  4. Gibt es eine APP?
    Gibt es eine APP?: Ich wüde die Seite auch gerne über mein Handy nutzen und da wäre eine APP perfekt. Habe leider noch keine App finden können. Gibt es eine oder ist...
  5. Mein erster Wartungungsintervall an 120d - wo und welches Motoröl?
    Mein erster Wartungungsintervall an 120d - wo und welches Motoröl?: Hallo, obwohl ich seit vier Jahren eigene Autos habe, kommt es nun tatsächlich zum ersten Mal vor, dass ich mich selbst um eine Wartung mit...
